The displayed object is operationally down. This impacts forwarding. HW resource limit may have been reached, see Release Notes.
Check the run-time limitation and compare this with the current configurations. Changing the system configuration such as deleting other tunnel(s) may help bring up the object.
Warning
Tunnel with remote endpoint %dst% and local endpoint %src% is operationally down for %str%.
| Name | Type |
| dst | IP |
| src | IP |
| str | String |
